Go Back   MobileRead Forums > E-Book Software > Writer2ePub
Old 09-21-2015, 11:05 AM   #1
draknan
draknan is a jewel in the roughdraknan is a jewel in the roughdraknan is a jewel in the roughdraknan is a jewel in the roughdraknan is a jewel in the roughdraknan is a jewel in the roughdraknan is a jewel in the roughdraknan is a jewel in the roughdraknan is a jewel in the roughdraknan is a jewel in the roughdraknan is a jewel in the rough
Device: Kindle 3
Not working with LibreOffice 5
Hi, seems that Writer2ePub don't work with LibreOffice 5.
draknan is offline   Reply With Quote
Old 09-29-2015, 07:33 AM   #2
mcdummy
mcdummy is a jewel in the roughmcdummy is a jewel in the roughmcdummy is a jewel in the roughmcdummy is a jewel in the roughmcdummy is a jewel in the roughmcdummy is a jewel in the roughmcdummy is a jewel in the roughmcdummy is a jewel in the roughmcdummy is a jewel in the roughmcdummy is a jewel in the roughmcdummy is a jewel in the rough
mcdummy's Avatar
Device: PRS-T3
It's mostly working on my System (Win 7 & 8.1) with LibreOffice 5.0 - 5.0.2. A problem exists with self-defined paragraph styles (w2e_xxx). Here, the text indents and margins are not exported to the epub. Instead, you get something like
.xxx {
text-indent: em;
margin-left: em;
mcdummy is offline   Reply With Quote
Old 09-29-2015, 10:14 AM   #3
mcdummy
mcdummy's Avatar
Device: PRS-T3
Just forgot to add that I'm using the 32bit version of libreoffice on an 64bit Windows. Writer2epub did not work on my system with the 64bit version of libreoffice.
Old 09-29-2015, 01:55 PM   #4
draknan
Device: Kindle 3
That is my problem, I use Windows 8.1 64bit with LibreOffice 64bit
Old 10-09-2015, 04:26 PM   #5
eBookLuke
Writer2ePub creator
eBookLuke knows the chase is better than the catch.eBookLuke knows the chase is better than the catch.eBookLuke knows the chase is better than the catch.eBookLuke knows the chase is better than the catch.eBookLuke knows the chase is better than the catch.eBookLuke knows the chase is better than the catch.eBookLuke knows the chase is better than the catch.eBookLuke knows the chase is better than the catch.eBookLuke knows the chase is better than the catch.eBookLuke knows the chase is better than the catch.eBookLuke knows the chase is better than the catch.
eBookLuke's Avatar
Device: Cybook Bebook iLiad Kindle HanlinV2 Readius SonyPRS500 SonyPRS700 etc
Hi all,
true, W2E is not (yet) compatible with some version of LibO5.
I am investigate about this problem, and will update W2E as soon as possible
Luke
eBookLuke is offline   Reply With Quote
Old 10-19-2015, 04:30 PM   #6
draknan
Device: Kindle 3
Thank you.
Old 12-29-2015, 05:08 AM   #7
skreutzer
Software Developer
skreutzer considers 'yay' to be a thoroughly cromulent word.skreutzer considers 'yay' to be a thoroughly cromulent word.skreutzer considers 'yay' to be a thoroughly cromulent word.skreutzer considers 'yay' to be a thoroughly cromulent word.skreutzer considers 'yay' to be a thoroughly cromulent word.skreutzer considers 'yay' to be a thoroughly cromulent word.skreutzer considers 'yay' to be a thoroughly cromulent word.skreutzer considers 'yay' to be a thoroughly cromulent word.skreutzer considers 'yay' to be a thoroughly cromulent word.skreutzer considers 'yay' to be a thoroughly cromulent word.skreutzer considers 'yay' to be a thoroughly cromulent word.
skreutzer's Avatar
Device: PocketBook Touch Lux 3
With LibreOffice 5.0.3.2, I can get the toolbar sporadically show up. I think the most reliable method to get it loaded is to install the extension, then deactivate and activate it again, then restarting LibreOffice. Toolbar appears as the first one left on the top without icons loaded, or as a undocked box in front of the document maybe. Not a nice solution, but a workaround for the time being, if you can reproduce.
skreutzer is offline   Reply With Quote
Are you using LibreOffice 4.4? Pinkie Writers' Corner 16 08-24-2015 06:28 PM
anybody using LibreOffice to compose? Gregg Bell Writers' Corner 80 08-22-2015 12:23 AM
Seriously thoughtful Does Libreoffice have a dictionary? Gregg Bell Lounge 3 04-26-2013 11:24 PM
LibreOffice V4.0 released this week. . . GlenBarrington Writers' Corner 20 02-16-2013 07:43 PM
Libreoffice or OPenoffice? PJinNH General Discussions 14 05-20-2011 06:13 AM
